Sensors of Humidity compatible with Labview ??
Hey,
I'm looking for sensors of humidity compatible with labview ans my comfiguration.
I have a PCI-6013 and a CB-68LP and I´d like to mesure humidity in an air-conditioning.
Can you help me I´would like to know which sensors could I use.
Thank You very Much
Message 1 of 25
(8,979 Views)
Any sensor with an voltage output conditioner will do the job.
We use rotronic HYGROCLIP.
If price matters, have a look at the sensirion sensors with digital output, they will use the DIO lines but need more software written.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 25
(8,940 Views)
there are humidity sensors from Testo ...
Ex: testo602 on RS-232: 4800,N,8,1
- you send J1 you have the humidity
- you send J2 you have the temperature
- you send J3 you have the dew point ...
In LabView, LabTab/Excel or anything, it is easy to get the measures
FG
Semou95 wrote:
> Hey,
> Thank You very Much
Message 3 of 25
(8,928 Views)
Although use this configuration 4800,N,8,1 there is not any data coming from the testo humidity sensors.
I`m using the testo 400 with 2 channels, I downloaded from the Testo webpage a kind of code, but; they don`t work with the serial port,and if i try to use the Labview example of receiving and sending signal from the serial it doesnt show anythin??
Any ideas??
Message 4 of 25
(8,512 Views)
first try to use this with hyperterminal.
and check if you have the right serial cable !
greetings from the Netherlands
Message 5 of 25
(8,502 Views)
I already check the cable, it is a RS232, I try to set a conection using hyperterminal, but nothing comes from the serial port.
A long time ago I was working with sartorius balances, and in that time at the beginning I was getting strings of unreadable characters of ASCII code, after I read some posts  I just had to set the parameter in the string code and started working.
For me, someting related to the format flow in Testo sending data is not right.
Message 6 of 25
(8,477 Views)
Hi
If also hyperterminal does not work, try another type of serial cable.
basically 2 types and a lot of subtypes exist.
The two types are straight and twisted, where twisted normally is called a null modem cable.
This one works when both systems use the same pins to send and the same to receive data.
Message 7 of 25
(8,473 Views)
Hello again, recently i found in the Indian Testo website http://www.testo.de/online/abaxx-?$part=PORTAL.IND.Applications&$event=show-from-content&externalid=... some code for many applications, one of them was for Labview.
Something different is in the approach that they use, they don`t work with the serial port, instead of that; they use the properties node and the invoke node. I downloaded and when I try to run them, they seem to be broken.
I`m not an expert, but when I try to fix them nothing seems to work, where did they find these invoke nodes?????
Message 8 of 25
(8,424 Views)
Have you installed toolbox?
I have tested the program labview with Testo 350 M/XL testo 454, it works for the control unit and 2 loggers, but not for analyzer box.
Lily
Message 9 of 25
(8,390 Views)
I installed the toolbox, but still I have to work in the *.DLL files, because in the opening of the automatition from the Activex show me the error -2147467263 related to general problem, I think I`ll search in the VB code to see why the error..
Mensaje editado por JOelei
Message 10 of 25
(8,377 Views)
