Serial Communications Failure
I am trying to communicate with a Tektronix 2022 Oscilliscope via an RS232 serial port. I have installed TekVISA which is Tektronix's version of VISA and I am using LabVIEW 6.0. Every time I that use HyperTerminal to communicate with the scope I read the correct identifying information, and when I use a program called OpenDesktop (which is Tektronix's program to read the scope) I am able to read info from the scope. However, OpenDesktop is limited in its functionality and I need to write a program in LabVIEW to average millions of data points. Unfortunately, every time I try to communicate with the scope via NI's tktds1k2k.vi I get errors that say that VISA open isn't working. I've tried NI-VISA and still I get the same results. How do I fix the VISA open? The program tktds1k2k.vi is on the NI download drivers page. I am using the example.vi.
(3,176 Views)
Unless you need TekVISA to run Tek's software, there shouldn't be any reason to have that installed. You could try uninstalling TekVISA and making sure that NI-VISA is only thing installed. You could also try turning on tulip support in NI-MAX and see if that works. I haven't tried it with TekVISA but I've had success with Agilent and NI-VISA installed at the same time.
(3,162 Views)
