Serial Connection Lost -1073807194
Dear All
I have  simple VI I am using to Transmit various different messages over a USB COM port (using FTDI chipset) to a device then carry out a subsequent RX.
Some messages do not result in a reply back from my device and in this case  I do not experience a problem, however when I use a message (e.g. send a  status request) that causes my device to give a reply I get the "Connection for the given session has been lost" error whilst  attempting the RX.
My RX is achieved by using a using a VISA get property node to get the no. of received bytes and then feed this to a  visa read. It seems the error occurs at the visa read. It seems inconsistent as occasionaly the error is not generated on the first TX & RX cycle, or during  the first few.
Although I have read some similar posts on here concerning this there are a few gaps which I need to fill to help me resolve the problem. I am using LV 7.1 on winxp service pack 2.
1) How can I find out my version of VISA as i understand an out of date version could be the problem
2) I have tried the documented trick of using the VISA set I/O buffer size but am usure of what mask value should be used if it is failing on  RX
Any help much appreciated.
(4,155 Views)
Hi
You can find the software version in MAx click on software in the right column.
Serial connection lost I do not recognize but is power handled correctly (how many mA is your device?)
greetings from the Netherlands
(4,146 Views)
Hi ATE Man,
I hope your well.
I am looking into your issue, but could you please only post once per issue.
I will only reply on your other thread (where there has been more activity).
This is the link.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,131 Views)
