Serial Data - String
I have a LVDT connected to my COM1 serial port. This gives me around 7000 readings when I read the COM Port. It outputs a string like "N +0.642...." to signify the flatness of a section. The problem is that I am getting a string (Read Data) like shown in the VI and am not able to convert it into an array of readings in DBL format, which is required for further processing.
I have attached the VI that I am using.
James
(1,428 Views)
double request
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Serial-Data-LVDT/m-p/4093820#M82049
Pleas keep the same message when asking.
greetings from the Netherlands
(1,419 Views)
