Serial Port Driver (?) VISA related error
Hi, I have an executable that uses the serial port to connect to an instrument but also GPIB to connect to other intsruments and I am facing the following annoying issue:
I have installed NI-VISA, 488.2 and NI-MAX but also Runtime engine in the deployment machine.  GPIB works fine in all cases. But serial port is not working (note that serial ports works via a terminal like PuTTY). When I try to check it via NI-MAX the open test panel returns an error "error opening resource ASRL1::INSTR Labview: (HEX 0xBFFF009E) Visa or code library" which typically means that some driver is missing. Then I moved to repair of NI-VISA which completes with an 1603 error
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9c0SAC&l=en-GR
When I restart the machine the serial port works OK. I can see that both in my executable application but also in NI-MAX "open test panel" which works fine and I can send commands.
If the machine is left turned on then the port is working. If I make a restart (or shutdown) then the serial port is not working (!) and it is needed to make a repair again and then after restart works again!.
I found also another way to make it work without enabling the repair process: I make a "reset configuration settings" in NI-MAX and then after a forced restart the serial port works again!
Any suggestions or ideas ?
BR, Stelios, Greece
(2,087 Views)
BR, Stelios, Greece
That error usually means another application most likely Putty has not released COM1 because Putty is still open.
(2,060 Views)
Hi, thank you for your response but the problem appears when I restart the machine without using PuTTY.
I am trying to solve this by various means, it is strange and annoying....
(2,046 Views)
That's not what you wrote in your first post. When I restart the machine the serial port works OK
(2,017 Views)
Hi again, thank you for your time.
It is a really strange issue. Please check what I was mentioned above:
"When I restart the machine the serial port works OK. I can see that both in my executable application but also in NI-MAX "open test panel" which works fine and I can send commands.
I found also another way to make it work without enabling the repair process: I make a "reset configuration settings" in NI-MAX and then after a forced restart the serial port works again!"
I am not sure if it is a NI or WIndows issue. I am working on setting another machine using older versions of NI-VISA, 488.2 and Runtime. The executable was made on Labview 2017 and I am using the latest versions of all the above. I am pretty sure that will not solve the issue.
Thanks again,
Stelios
(2,009 Views)
Again, you are making contradictory statements.  It makes NO sense.
How is restarting and make a restart  different ????????
(2,006 Views)
I work for a company, another colleague has the same issue.
I am describing what is happening which is very strange but is a true problem.
Only a video session would help to see that this actually happens!. If needed I can do it.
BR,
Stelios
(2,000 Views)
