Serial Port renaming problem
We have a problem with the PXI system in our manufacturing.
The Serial Ports Com2,Com3 can not be used.
They are "blocked" by Windows.
We have 1 Serial Port (Com1) in the PXIe8133 Controller.
Then we use the PXI8430/8 with 8 Serial Ports (normally Com2-Com9)
Com2 and Com3 can not be renamed. It pops up an error message .
I attach a screenshot of the problem to show
Thanks for support
(3,434 Views)
i think COM 2 and COM 3 is not "blocked" but "in use". You can not use the same Port number for multiple COM ports. So why not using COM 4 - 11 for your PXI 8430?
If you need COM 2 and 3 for you PXI card you first have to change the COM Port number of the build in COMs.
Hope that helps.
Cheggers
Sascha
(3,407 Views)
