Serial Write & Read.VI configure port error
On the Windows XP partition of my PC I can run the VI examples that use the serial COM ports. On the Suse/Linux partition however, most of the VI's run well, except those with serial ports, such as "Basic 2 Port Serial Write and Read.VI". They stop with the message: Error -1073807202 occurred at Property Node in VISA Configure Serial Port... The error code is undefined..."
(4,096 Views)
The error code means that VISA is not installed.
(4,085 Views)
I had the same problem and after intalling the VISA driver on my PC the problem was resolved. Try it .
Bye
(4,073 Views)
you can find the NI-VISA by clicking on the link:
https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
Best regards
Alex
NI Switzerland
(4,060 Views)
