Serial communication differences between rs-232 and rs-485
I'm trying to modify a VI that -- one that was not originally created by me -- to communicate with an instrument (specifically, a Eurotherm 2416 controller) via a serial connection.  The trouble is, the original connection to the device was successfully made via the RS-485 standard, and I'm using RS-232 instead.  I've taken a look at the VI and it's sub-VIs and it seems to use the standard "Bytes At Serial Port" and "Serial Port Read" VIs to communicate to serial devices.  I don't see any way to change the type of connection from RS-232 to RS-485 anywhere, though, and the VI doesn't seem to work correctly -- it just gives me an error of "no data found at serial port".
How do these sub-VIs know whether to communicate via RS-232 or RS-485, or is this a user-definable setting?  If so, where is it?
Thanks for any help in advance.
(4,619 Views)
main differences (may not be totaly wrong 😉 :
physical way of communication: GND ref. voltage (232) to diffential (current?) loops (so the connector might look equal, but the pinout and signals are not)
point to point vs bus (so for the 485 a more complex messaging is needed,  adresses , checksums)
look for a KB article , I'm shure there are some on the ni sites or at wikipedia
Greetings from Germany
Henrik
LV since v3.1
(4,599 Views)
The difference is the physical interface. Seen from SW it makes no difference if the link is 232, 485, 123 or whatever.
485 is a differential voltage interface with no direct ground reference between nodes. But is must be within a range specified by the interface circuit.
With 485 you can connect more then 1 node directly (with 232 you can do this indirectly) When you want to address more then 1 node then you need the a more complex protocol like ModBus (but there are many more)
So you can use a 485 point-to-point connection just like you use a 232 connection with no change needed in SW
(4,595 Views)
Could you please share the rs485 vi with me?
(3,361 Views)
You are answering to an eight year old post.
A serial VI communicates with a COM port. Whether the data is transported over RS-232, RS-485, plumbing, smoke signals, ec. does not change the VI.
So asking for a RS-485 VI ......
Kees
(3,359 Views)
