Serial communication don't work using Runtime Engine
I have made an executable file of my LV program.  But the serial communication with the Power Supply don't work when i run the .exe file.
I have installed the instrument driver, and the VISA Runtime Engine in addition on the actual PC.
In my VI, I have used the instrument I/O assistant to communicate with the Power Supply.
Is there any suggestions why the communication not is working in the .exe - file?
(4,064 Views)
What is the error message that you get?
greetings from the Netherlands
(4,063 Views)
I don't get any error message at all.
(4,061 Views)
OK
what version of LabVIEW, VISA etc are you using and if it is a small program, you can attach it.
and what version of the driver are you using.
(4,037 Views)
Thank you for your replies.
I uninstalled all the NI software on the Standalone PC, and included everything I needed in the Apllication Builder. Now, the communication is working.Smiley Happy
(3,992 Views)
