Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Serial communication with PLC SIEMENS SIMATIC S5-115U (941 CPU) with Labview 6i
LormanZ
Member
08-26-2002
12:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to conect to a PLC SIEMENS SIMATIC S5-115U (CPU 941) with a PC using only the serial port (COM1). I need to use Labview 6i software.
Has anyone use a VI that can do that?
Does the 941 CPU (SIMATIC S5-115U) support AS511 protocol?
0
Kudos
Message
1
of 3
(5,368 Views)
Reply
Re: Serial communication with PLC SIEMENS SIMATIC S5-115U (941 CPU) with Labview 6i
Ben
Knight of NI
08-26-2002
08:28 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you search the entire NI site for AS511 there is a hit that lists The Siemens AS511 as supported under Lookout.
You may want to inverstigate that route.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 3
(5,368 Views)
Reply
Christ0phe
Active Participant
05-23-2003
07:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
http://www.citeng.com/
I use their 3964R Vis for 10 years.
Christophe
0
Kudos
Message
3
of 3
(5,368 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
