Serial communication
When I send characters out over the serial link in LABView 7.1 ( using VISA) are they treated the same way as if I used a Hyperterminal ?? Is the command "dw 0x80000" ( dump a word at address hex 8000)at the serial interface converted to the same ( ascii)characters whether I use Hyperterm or VISA? The processor doesn't seem to understand the cmd when I use LV7.1 but does w Hyperterm.
(3,124 Views)
VISA and Hyperterminal send the same characters. What might be different is the communication parameters (i.e. baud rate, parity, etc.) or you might not be sending a termination character. See if the processor needs a LF or CR at the end of the command in order to process it. If it does, add the control character to the end of your string. You can do this by using the concantanate string function and the character from the string palette or using a VISA Property node (i.e. VISA Configure Serial Port) to automatically add a term character to each write.
(3,124 Views)
