Serial device driver doesn't support DTR escape code
Gary,
Looks like we need to change the code to the following:
#include <rs232.h>
#include <utility.h>
int main (void)
    int iStatus;
     iStatus = OpenComConfig (3, "com3", 9600, 1, 8, 2, 512, 512);
    EnableBreakOnLibraryErrors ();
    if (iStatus == 0)
        SetXMode (3, 0);
        SetCTSMode (3, LWRS_HWHANDSHAKE_CTS_RTS);
        SetComTime (3, 1);
    // Configure com ports for 2-wire mode communication.
    iStatus = ComSetEscape (3, WIRE_2_ECHO);
    iStatus = ComSetEscape (3, SETDTR);
    iStatus = ComWrt (3, "abcdefg", 7);
    iStatus = ComSetEscape (3, CLRDTR);
    return 0;
We don't need niserial.h since we're using the CVI serial library and the handshaking mode needs to be set to LWRS_HWHANDSHAKE_CTS_RTS.  Using LWRS_HWHANDSHAKE_CTS_RTS_DTR turns control of the DTR line over to the driver; that's why we get the error.
Here's some other comments from R&D about bias resistors:
- We don't have bias resistors on the Tx pins and so when in 2-wire mode and not transmitting they will float unless a 2-wire cable is attached (since that will connect the Rx pins which are biased to the same lines as Tx)
- For RS-485, Rx biasing causes "Rx+ minus Rx-" to be pulled positive (which is equivalent to the idle state, i.e. no data being communicated).  It's kind of the opposite for RS-232 in that the idle state is with "Rx minus Gnd" being negative.  Also, RS-232 isn't biased.
Please test out this code and let me know if it fixes the error for you.
Thanks for your patience,
Robert Mortensen
Software Engineer
Message 11 of 11
(1,015 Views)
