Serial port problem
Hey everyone,
There's a problem when i'm using Labview communicating with a serial port device. The device is always responding what i sent to it. When using NI VISA, the same thing happens. But everything work properly when i use windows Hypertrm. I wonder if the string should be processed in some way, or the basic serial port example in Labview just can't work properly communicating with other devices. What should i do?
(3,185 Views)
Well, i got it. The terminal character should be \r instead of \n......
(3,182 Views)
