Serial usb and Analog data DAQ
I am planning to use NI9205 to obtain some analog data, but as the same time, I also need to acquire and synchronize some data from a serial port (RS232 to USB),are there any examples showing this case? Thanks
(3,508 Views)
Zeph,
I'm afraid you have a fairly unique request.  I found some other issues dealing with something similar on another discussion forum.  However, I have questions on how you want to perform this synchronization since serial does not rely on a sample clock.  The closest I think you could get is synchronizing the start time of both of the tasks, which you could do by combining the serial read/write examples found in Example Finder and your start task.  Good luck, post back if you have further questions.
Sincerely,
Chris G in AE
(3,468 Views)
