Serial vs Ethernet communication for gas analyzers
I need to control several Thermo gas analyzers through LabVIEW and each has an RS-232 port and an ethernet port. Has anyone does this kind of thing before? I just want to get a sense of which would be easier for programming and communication purposes.
(4,291 Views)
First, have you done a search for an existing driver? You can go to the Tools menu and select Instrumentation>Find Instrument Drivers. The main page for drivers is the Instrument Driver Network where you can also do a serch and find resources on what a driver is and how to create one. With the VISA api, you can create a driver that will handle both serial and ethernet (or USB, GPIB, etc) with very little extra work. Look at the example driver that comes with LabVIEW - the Agilent 34401. This instrument has GPIB, Ethernet, Serial, and USB options. The only thing in the driver that is specific to a specific interface is one case statement in the Initialize function. VISA abstracts all of the differences in physical interfaces.
(4,286 Views)
If you are using the Thermo Scientific analyzers and TCP/IP, make sure that the Unit ID in the MBAP header is the same as the numeric part of the model number for your specific instrument. For examples, see the code I have posted to read Thermo Scientific ambient gas analyzers over TCP/IP:
https://github.com/dhhagan/ThermoLabVIEW
- David
(3,365 Views)
