SignalExpress: change IVI power supply during run
I'm using SignalExpress and I want it to change the IVI power supply level from 20Vdc to 30Vdc after 10 minutes of testing.
How do I do this?
(3,269 Views)
Hey Evie,
Something you could try to do is use "Run labVIEW VI" Function. With labVIEW you can use the Serial or GPIB vi's to send the correct message to your instrument.
LabVIEW Demo
I don't think Signal Express will allow you to send custom commands, but labVIEW will.
Nick D.
(3,253 Views)
You can do this with a sweep operation and the IVI Power Supply Step
(3,243 Views)
