Silent/Unattended run of Add GPIB/ENET wizard
I'm looking for a way to run the Add GPIB/ENET 100 wizard automatically.
I found the addhardware.exe opens the Wizard, but I requires clicking "Next", and I'm looking for a way to suppress this interaction.
I suppose the wizard updates some registree keys or writes to some .ini file, if so, maybe I could write a .bat file which will perform this instead.
Has anyone encountered this problem?
I've found a similar question here, but without a positive answer.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Is-it-possible-to-Modify-GPIB-Interface-list-...
I'd appreciate any help.
Thank you,
Maya.
(3,389 Views)
Hi Maya,
The GPIB/ENET 100 wizard is meant to be an interactive feature to help install and configure the device. You may be able to just create a batch file with return characters and the appropriate wait times between screens.
Best Regards,
Swathi B
(3,358 Views)
Thank you for the reply.
Maya.
(3,335 Views)
Hi Maya,
I was also able to find out that the wizard, in fact, modifies the GPIB.ini file located in C:\Documents and Settings\All Users\Application Data\National Instruments\NI-488.2 on a Windows XP machine. You may be able to use a script to populate these values; however, do be aware that not entering appropriate values could lead to unexpected behavior.
Best Regards,
Swathi B
(3,299 Views)
