Simple Threshold test using Keithley 2000 and 2430
I am just learning instrument control via Labview and decided to dive in a test to jumpstart it.
I was able to connect our Keithley 2000 DMM and 2430 Sourcemeter and run the labview examples successfully.
Now I wanted to ask for some advice and direction in making a threshold test for a supply monitor device.  I would generate the ramp using the 2430 on the input/sense pin and  monitor the reset pin using the 2000.  My first attempt, I increment the sourcemeter a few millivolts at a time then stop when the DMM detects the reset is active.  However, this proved to be so slow, especially when I want more resolution determining the thresholds.
So I plan to use the 2430 sweep generating function.  But I foresee a problem in trying to sync both instruments.  Can anyone suggest a better way to implement this? Then I will try to build my code and post it here for further comments and suggestions.
Thanks in advance...
(3,746 Views)
depending on your device?
is the circuit designed to survive a too high current?
Or can you use the timing in the 2400 sweep to stop when a digital input "aborts" the sweep.
I know that you can link keithley instruments via the digital IO pins but the keithley 2000 stays slow.
greetings from the Netherlands
(3,736 Views)
Thanks Albert.  This is for testing 3-pin microcontroller supply supervisors like IMP809 or MAX803.  I will be using no load to simplify things and force voltage only to Vcc. So I don't really need to abort the sweep.  But trying to mark the threshold point on the sweep is kind of tricky (at least for meSmiley Happy)
By via digital I/O, you mean the trigger link? I'll try to find a cable for that one and check if it will bring a much quicker result.  But since I will be doing the trigger setting through Labview, I also think that it will not be as fast.
Once I got the equipment back, I will try to use the sequencing frame to make sure the sweep and the Keithley 2000 measure loop will run at the same time. I hope the program will be able to tag the threshold point. Maybe this will take care of the timing. Looks like its not as simple as I hoped it to be.
I'm not sure if this is the right way to do it but learning is all about trying things out.  I wonder if there is any other way to do it.  Its good to learn the hard way.
(3,720 Views)
Hi
With timing I mean NO sequence frames!
Sequence frames are not the best way to sequence things in LabVIEW.
Normally the error in-error out is used to have sequencing by wire. It is much batter readable and also gives you an idea where it went wrong.
(3,710 Views)
Hi araneve,
Synchronization is usually done at hardware level in cases where you need precise triggering. I would strongly recommend contacting Keithley about it. I've also included a few of general articles on synchronization below for your reference.
Synchronization Basics
https://www.ni.com/en/support/documentation/supplemental/10/synchronization-explained.html
Timing and Synchronization in NI LabVIEW
https://www.ni.com/en/shop/labview/timing-and-synchronization-in-ni-labview.html
I hope this helps.
Josh L.
(3,708 Views)
Wow, great stuff! Thanks Josh, that is a good read and will try to figure it out in the block diagram.
Thanks too, Albert.  Believe it or not, I also did try this before I made the thread and found how silly of me to use the compare function without understanding the data type I should use.
Greatly appreciate the help.  I'll start to code and try things you guys suggested.
Best regards
(3,702 Views)
