SimpleStep motor controller board
Update:
Turns out to be a hardware issue.
We have two USB-serial cables. One has a Prolific chipset. The other has a different chipset.
The one with the Prolific chipset works fine.
The other doesn't. It's driver may not be quite compatible with Windows 8.1.
Though it worked fine with a different piece of equipment.
The cable with the Prolific chipset was recognized instantly in Windows 8.1
Message 11 of 14
(2,731 Views)
good work
Expected that from you.
greetings from the Netherlands
Message 12 of 14
(2,729 Views)
Can you check the handshake lines?
Sometimes (when some galvanic isolation is involved) you need to 'power' the rs232 circuit in the device.
NEXT: REALLY check your cable!!
Do you have switched and or high power devices near ?  (Oh yes, the stepper motor 😉  )  check your GND lines for a clean gnd line to the PC !!
EDIT ... too late 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 13 of 14
(2,729 Views)
Also, a co-worker had another USB-serial cable with FTDI chipset. Needless to say this cable also worked fine.
Message 14 of 14
(2,725 Views)
