Simultaneous acquisition of waveform on multiple channels of NI PXIe-5105 in LabVIEW via IVI driver
for my master thesis I work on setting up a test bench to measure short-time (< 1 microsecond)  electric contact interruptions. I use a NI PXIe-1082 System with a PXIe-8840 Quad Core and two PXIe-5105 Oscilloscopes.
Now to my question(s):
I am new to the usage of IVI drivers and was wondering if I can acquire the waveforms on multiple channel simultaneous (I've so far only found VIs regarding a single channel).
I know that a VI can be set to be called upon in multiple instances, but does the same go for the dll library the VI calls upon?
And can the device even handle simultaneous commands for different channels?
Greetings,
Max
Message 1 of 1
(2,376 Views)
