Smooth current transition
I am currently trying to control 3 like power supplies using the gpib bus. I need to sweep slowly from one current level to the next to avoid any overshoot. Is there an easy way to accomplish this?
(4,101 Views)
It all depends on what the instrument is and what sort of command structure it responds to. The GPIB controller is limited in the fact that it can only send ASCII (or 8-bit) data to and from listeners. Whether some of the ASCII commands are understood is 100% a function of the instrument. I might recommend looking through your instrument's manual or contacting the vendor about a specific command structure that is needed to achieve the control you require.
Ryan Mosley
National Instrument, Applications Engineering
http://www.ni.com/exchange
(4,101 Views)
