Solartron 1260 with 1287
Yes, I am using the 1287 with this.  The ZPlot software uses an NI GPIB board so the spy program, or I/O Trace as it's now called can run while the zplot software is running.
I will have to learn a little more on how to initialize different instrument (GPIB).  My only other experience about a year ago was writing some testing software but it was on a pxi 1042 platform.  It's a little different than the GPIB.
I do have the manual, what I'm going to do is break it down step by step using the i/o trace and see if I can mimic the current application.
I will post back here later on today with my results.
Message 11 of 13
(2,033 Views)
Accepted by topic author tartar813
Ok, got the test running and correct results...  Probably 50-100 commands to get the test and run the test.  I just went line by line with the I/O Trace and mimic'd the commands.  Nice to have a working solutions in which I can copy off of.
Also nice that they were already using a NI board so I can get all the info that I needed.
I just have to cleanup the interface and put the results into the database and I am finished.
Thanks!
Message 12 of 13
(2,010 Views)
could you please tell us how to do it?
Message 13 of 13
(1,143 Views)
