Static and unstable frame problem in grabbed image of Basler camera in NI MAX
Dear all,
I'm using two Basler A602f cameras in my experimental setup. Few months ago last time I've checked, two of them were working good. Now one of them is good, the other one is giving an undesired image output (static and sliding frames, as seen in the attached picture). I'm using NI MAX to see if they are functioning properly. In LabView I don't have an issue. I can record the image (the bad one). So I don't think there is a connection problem. Also nothing has been changed with the system in the meantime, so I don't know why it stopped working properly. I've checked the cables, connections etc, also played with camera attributes, formats etc.. Nothing changed it.
I've contacted the Basler customer support but they won't provide customer support on that product anymore, since it is a relatively old model.
Important system information:
Labview 2016 v. 16.0f5 (32bit)
IMAQdx 16.1.0.
I'd be very happy if anyone could comment on this,
Kaya
Message 1 of 1
(2,448 Views)
