Step input
Dear All
I have programmble power supply , i want to set the current of the power supply in steps of 0.2A  and each step input should  update every 2min to change the set current of the power supply. I develop the arrays using ramp pattern as i attached below and from my program i can desplay the step values after 2min each . But how can i arrange the setp inputs and update every 2min for my power supply.
Regards
bstar
(3,726 Views)
None of that makes any sense. Wire the ramp array through a for loop to your power supply VI. Place a wait function inside. Done.
(3,710 Views)
Dear Dennis Knuston
Sorry, I am not clear with it. Could you help me .
Regards
Bstar
(3,707 Views)
It's simple. You should take the LabVIEW 101 tutorial.
(3,705 Views)
