Stop serial port from transmitting NULL character
When using Labview serial VISA write, it always puts a NULL character at the end. How do I eliminate it so that I can achieve the same result as using a hyperterminal, which does not transmit extra unprintable characters?
I tried turning on DISCARD NULL CHARCTERS property for the VISA but it only has effect on serial read but has no effect on Serial Write.
If I turn off ALLOW TRANSMIT property, it does eliminate the NULL character on write, but there is a long delay.
(4,450 Views)
I am not sure what could be happening here. You might want to turn on NI-SPY and look at exactly what is being transmitted. What is the hex value of the "NULL" character that is being sent? Could this be a classic CR vs CR/LF problem?
Hope this helps out!
Best Regards,
Aaron K.
Application Engieer
(4,450 Views)
Attached is how I transmit text without sending extraneous characters.
I took this from the example that comes with labview on basic serial.
(4,037 Views)
