Suggestions?
This is a bit detailed but I would appreciate any help
I am new to LAbview and am doing a project to track the motion of the hand. A cubic box with Analog gyroscopes(angular rate sensors) and accelerometers(measure accelerations) on various surfaces is mounted on top of an AnalogADUC814 microprocessor containing a transmitter. The captured gyroscope data(in analog) is sent to the analog i/o pins of the microprocessor while the accelerometer data(digital) is sent to the timing ports of the microprocessor. This data then leaves the microprocessor in hex form and is transmitted to a receiver board next to the PC via a Radiometrix transceiver. I have written code(as shown in attachment) to capture the data from the accelerometer and gyroscopes but I would like to know how best to get the data on to Labview and display it. Previously a second PC program would have been written but we are hoping to use Labview to avoid the second program
The structure of the system is shown in the attached file
also
Any help would be appreciated
Message 1 of 1
(3,145 Views)
