Switch between pxi4130 current ranges fast?
PXI 4130 current level has these ranges (among others):
a) 4mA to 200mA
b) 400uA to 20mA
First I want to source 50 mA (first current range).
Then I want to switch to 100uA (second current range) as quickly as possible.
I do not need the full accuracy available. Error on either current (+/-10% even) would be acceptible if it were repeatable.
Is it possible to get from (a) to (b) without disconnect/reconnect or stair-stepping the current and range to an overlapping value?
(3,393 Views)
PS LabWin CVI
(3,392 Views)
While in the running state, you can edit the source configuration dynamically using any VI, function, property or attribute listed in the following tables.
-Ciao 😉
(3,337 Views)
Thanks, but that does not help.
While it is true that you can edit the source configuration dynamically with those functions, I do not see how you can use them to change source current between ranges without disabling or stair-stepping.
Try 1:
Source current 1 (OK)
Source current 2 (ERROR: new current not in the old current range)
Try 2:
Adjust current range (ERROR: new current range does not contain the current still being applied)
What I don't want:
Disable output (OK)
Adjust current range (OK)
Source current 2 (OK)
Ensable output (OK)
Or:
Source a middle current that works for both ranges (OK)
I think Im SOL.
(3,315 Views)
