05-16-2006 12:04 PM
05-17-2006 09:28 AM
05-17-2006 10:19 AM
05-17-2006
10:40 AM
- last edited on
08-10-2026
09:00 AM
by
Content Cleaner
Hi ChaeS,
Although I do not think it is the source of the problem, I would recommend downloading and installing NI-488.2 version 2.4 from our website, along with NI-VISA 3.6 (If you are using NI-VISA). The next step I would recommend you take is to use the NI-Spy utility to capture the driver calls made when you are experiencing the slowdown.
By looking at the calls captured by NI-Spy, we should be able to tell if your application is introducing the delays between driver calls, or if the driver calls themselves are taking a long time to complete. You can find instructions for performing a capture using NI-Spy in this KnowledgeBase.
Once you have captured the driver traffic, double clicking on any line will give you the timing details to let you determine how long the call took. You can also save the .spy file and attach it to a post here and we can help interpret what you have captured, but we may need you to point out lines which correspond to the delays which you are seeing.
Jason Smith
