Sync proble in MODBUS DEVICE controlling
    Hi
i am interfacing partlow MIC 1462 controller supporting modbus  RTU protocols.
I found a string in the manual that gets the process value from the device .
Also i installed the portmon recommended by uncle bump to see whats actually transmitted and rx by the software by the company.It showed that it continuously sends the string of
8 bytes  and then reads the data  1byte at a time  like this:
tx: 01 03 00 01  00 01 D5 F9
RX:01
RX:03
RX:02
RX:00
RX:4F
RX:BD
RX:B0
Now i used the LV VISA in hex mode to transmit the string
but the responce from the device comes very fast and  its not synchronized i guess.
so please tell me how can i read it byte by byte. Are there any settings for the buffer?
are there any specs of buffer which i should consider?I dont know what is wrong.I want to catch the proper string. So please give me any detail you can to help me.
Thanks and looking forward.
(3,210 Views)
Hey ssddii,
Can you explain what you mean the information is coming in too quickly?
I'm wondering if you could make a software work-around to it.
Also, something worth taking a look at is the following article
If you have all the items required, you could go through the following Demo.
Nick D.
(3,183 Views)
