Synchronizing serial aquisition with CTS / DTR signals
I am creatinga VI (my first) to read 4 bytes from the serial port and concatenate them into a 32 bit word. I have figured out how to do the concatenation etc. but am having difficulty figuring how to use a pulse on the CTS or DTR line to "frame" the 4 bytes. I am now familiar with the VISA resources and how to monitor the CTS / RTS etc. I am just having trouble with the process as follows.
1) wait for CTS pulse (from peripherial)
2) Then grab the four bytes
3) concatenate the fourbytes into a word
4) send word out to be used in a "waveform" format.
My hadware is an FPGA that is connected to an A/D. I have the FPGA send a pulse on the CTS line to the PC on the transmission of the first of 4 bytes.
Any
help or pointers are much appreciated.
(3,897 Views)
What is the purpose of the CTS pulse - are you trying to use the CTS pulse as hand shaking? Or are you simply saying "here comes 4 bytes". Is there other serial traffice that should be ignored when CTS is not asserted?
(3,897 Views)
The purpose of the CTS pulse is just to say here comes the start of a 4 byte chunk. There is no other traffic on this line. I am merely using it to keep everything in line. If you miss one byte for what ever reason everything goes to crap after that.
(3,897 Views)
Since you are only waiting for 4 bytes there are a couple of ways to do this. One way is to not use CTS and just perform VISA reads until you get 4 bytes. Or, you could use CTS and perform a VISA read of 4 bytes on a VISA (CTS) event.
(3,897 Views)
