11-28-2006 07:42 AM
11-28-2006 01:42 PM
Q3: Resolved. After the ibdev32() I just do a ibwrt32() with "ID?" and compare the result.
Q2: Should read as below:
I have a GPIB-USB-A on a laptop, and each time I breakdown then setup the system, Xp has lost the gpib driver and I must run thru the Add Hardware screen. How can I change the config so that it automatically loads the driver when its plugged in (without have to manually run Xp's Add Hardware)?
Q1: Still need this info
11-30-2006
06:11 AM
- last edited on
05-27-2025
01:22 PM
by
Content Cleaner
