TAMS 81488
Dear Sir,
I would like to find one gpib card could replace TAMS 81488 (http://www.tamsinc.com/hpib/81488/index.htm) .
Does TAMS 81488 compatible with NI GPIB Product include API?
nonomiya
(3,244 Views)
What api are you using? VISA is the only portable API so if your application uses that, then you can use an NI GPIB board. Obviously, the low level windows driver will be different.
(3,242 Views)
