TCPIPSession has no ControlRen method, need to put instrument in local mode (remotely)
I noticed there is no ControlRen method in the TcpIpSession class as there is in both the GpibSession and UsbSession classes.  In my application I need to tell the remoted instrument to "go to local", which I can do in the latter two classes.  However, if the instrument is connected to the host via TCP/IP there is no way to do this that I can see.
Here is a snippet of code from my base class for communicating with the instruments:
The session_ variable is of type NationalInstruments.VisaNS.Session
public void goToLocal()
     if (session_.GetType() == typeof(GpibSession)) ((GpibSession)session_).ControlRen(RenMode.AddressAndGtl);
     else if (session_.GetType() == typeof(UsbSession)) ((UsbSession)session_).ControlRen(RenMode.AddressAndGtl);
     else { /* do nothing, TcpIpSession does not have a "go to local" method */ }
Can anyone help with this?
(3,812 Views)
Hi Randy_Leonardi,
The question I have right now is what sort of instrument are you communicating with in your application through the TCPIPSession? I ask because there is the possibility that the instruments that can be communicated with through TCPIP are not compatible with local/remote calls or possibly not specifically with our VISA communication. Looking through the documentation it appears we only support local/remote settings through GPIB and USB type sessions (at least within the VisaNS namespace).
James W.
(3,790 Views)
When I connect to my instrument using ResourceManager.GetLocalManager().Open(visaResourceName), it returns a TcpIpSession object.
When that happens, the instrument will remain in remote FOREVER unless I physically press the Local button on its front panel.
As you have seen in the docs, and I stated in the original, GpibSession and UsbSession allow you to command the instrument back to Local control.  I need the same ability when connected via Ethernet.  Even calling Session.Dispose() does not take the instrument out of remote.
Is there a way to do this?
(3,760 Views)
What is the instrument that you are connecting to?
Ian M.
(3,739 Views)
