TI AFE4490 on labview
I am currently working on the following project:
With an acquisition card (AFE4490) manufactured by TI (they don't broadcast labview source code , or the driver for use directly ), I should be able to process the values in real time in labview . The card is connected to the computer via a USB port, but the chip communicates using a SPI port.
To do this, they gave me the datasheet of this card and the main operation is to write the different registers in this card from labview . I have a sheet with 30 registers with  addresses and corresponding reading and writing addresses.
For example, after the initialization of the card, the first operation is LED2STC , address 0x01 and address read / write 0x0017C0 .
The doc says that the chip has 32 bits , it uses the first 8 to write the address and uses the 24 other to write the reading and writing addresses.
So I wanted to know how it was possible to enter these registers in labview ?
Attached a sheet with the list of the registers.
Damien
Message 1 of 23
(7,882 Views)
NI offers the 8451 for SPI communication.
https://www.ni.com/en-us/support/model.usb-8451.html
Message 2 of 23
(7,872 Views)
Thank you for your reply but I'm in charge of this project over an unpaid formation, so I thought more programming ideas in labview directly. I saw a feature that allowed to write a 32-bit block, that is what I want, but I don't know how to wire it.
Damien
Message 3 of 23
(7,857 Views)
LabVIEW is software and you'll need some sort of hardware. What are you planning on using?
Message 4 of 23
(7,850 Views)
What do you mean?
Message 5 of 23
(7,847 Views)
How are you planning to physically connect to the spi port?
Message 6 of 23
(7,835 Views)
The chip is integrated into the capture card and is connected to the computer via USB.
Message 7 of 23
(7,829 Views)
Sorry, I thought you meant it had a separate port.
You will have to get details on the USB communication from TI. Did they provide anything at all on how to connect and read/write to it? How does the device appear on Windows device manager?
Message 8 of 23
(7,820 Views)
Yes here is the datasheet, page 47 to 73 it explains how to read and write data, but there is no link with Labview...
There is a software that was installed with the card, but it does not meet expectations because it does not allow to take continuous measurements, unlike Labview.
I use Measurement and Automation software that allows me to see the TI card and access its properties and see its attributes.
Message 9 of 23
(7,804 Views)
You attached the data sheet for a component - not a board with a USB port. You need something that explains the serial communication that the USB is emulating. Contact TI for the correct manual.
Message 10 of 23
(7,795 Views)
