TNT4882 IEEE 488.1 capabilities analyzer
We are developing a product with TNT4882 chip.
Is there an automatic/semi automatic test to check which of the IEEE488.1 capabilities our instrument pass?
With the IEEE488.1 capabilities, I am referring to (SH1, AH1, Tx, TEx, Lx, LEx, SRx, RLx, PPx, DCX, DTx)
I imagine it could be some test that could run from NI MAX through GPIB-US-HS/+ connected to our instrument for example.
(3,120 Views)
Can you explain me the hardware setup that you have for your chip.
(3,014 Views)
We are using TI DSP (TMS320F2837xS) to talk with the TNT4882 chip through DPS GPIO's.
We use the ESP-488 NI C library in the firmware. The TNT chip is configured in the normal 7210, One-Chip Mode.
Let me know if you need more information.
(3,009 Views)
