TNT5002 Boundary Scan
From the pinout in the datasheet it looks like the TNT5002 is able to act as a boundary scan device. I might want to use this feature and therefore I have the following questions:
- Where can I find a BSDL file for the TNT5002?
- In the datasheet the JTAG pins are not described. Is there an example on how to use the those pins? Any special needs like pulldown or pullup resistors?
Thanks and best regards,
Patrick
(2,590 Views)
Hi Pruf,
It seems like BSDL files are not available anymore on the NI website. If you have a support access I suggest you to contact them.
For the JTAG pins I have found this page that will help you on how to configure the device : https://www.ni.com/fr-fr/support/documentation/supplemental/18/pins-tck--tdi--tdo--and-trst-on-the-t...
Alexandre
(2,307 Views)
The BSDL can be found in this link.
(2,294 Views)
