TTI AWG TGA 12104 automatic Setup files
I am using TTI AWG TGA12104 waveform generator and I have created some 10 setup files which has different waveforms with different amplitudes. I want to run all these setup files at a certain time interval. There is no provision to do it with usb connection or any other connection. So I thought of changing the c code which was given in VC6 folder of USB/Examples but I am not able to run the executable which has been produced at the end. So i thought of finding a way around using labview. Can anyone help me find a way of running all those setup files continuously using labview?
(2,454 Views)
Hi raj20396,
It would most likely be possible to use LabVIEW to do this, but it's hard to give specifics when I don't have familiarity with that hardware. If you want a good starter, the article below should get you going in the right direction.
USB Instrument Control Tutorial
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
Best,
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,402 Views)
The command set for this instrument appears to follow SCPI format.  You could easily set up a text or Excel file to be read in allowing the instrument to be configured as desired when required.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,393 Views)
