Talking to two devices, at the same time.
That is it!
Many thanks Albert.
So just for explanation, what is the difference between sending *STB? via write and STB VI?
Message 11 of 14
(1,932 Views)
The function works in the gpib interface. The *STB works via the next level higher.
The function only returns a byte directly on the bus. The *STB string has to be interpreted in the machine and then a byte has to be returned.
Nice that you saw it works.
greetings from the Netherlands
Message 12 of 14
(1,931 Views)
Albert,
But generally, how to get know what functions work in the GPIB interface and which function work on the next level higher?
There is no a lot of explanations in the LV help.
Message 13 of 14
(1,923 Views)
This is the only function that works at the chip level.
It is very specific for gpib and I understand why it is not documented. It is too low level.
In fact it is a pity that the other command also exists, because it is not needed.
Message 14 of 14
(1,920 Views)
