Tektonix DPO continuous acquisition
@d91 wrote:
Thanks, but I need the oscilloscope to do that
Why?  You will spend a lot more of your time trying to fix a square into a round hole than using a device that is made for what you are trying to do.  If you spend more than a day or two trying to get the scope to work, you have already spent more money trying to get the scope to work than it would be to just buy the USB DAQ device and use DAQmx.
Message 11 of 14
(2,568 Views)
And Tek had told you that LabVIEW can't be installed or have you decided you can't use any of the built-in software?
Message 12 of 14
(2,563 Views)
Hi Dennis
I can send you the vi that I had written for this. Care to have a look??
Message 13 of 14
(2,556 Views)
I would assume that the code is from the driver at http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=10128 and you do not need to attach it. I do not need to look at it either since I believe that what you want to do is not physically possible with GPIB technology.
Message 14 of 14
(2,543 Views)
