Tektronix MDO 3034, read data from the scope to PC in CSV format via USB
Hello, could someone suggest the code for getting a measurement from Tektronix MDO 3034 scope?  I need it in CSV format (time column, and amplitude column). I also need code for setting the trigger level, after which the scope willl wait and trigger the next scope waveform reading when the trigger level is deteccted. I downloaded the drivers from the NI site, and "installed" them. Howerever, i don't see them embedded in the instrument pallett, so I am not sure how I am supposed to use those drivers. I have Labview 2014, and the drivers are for the 2016 version, maybe that is why....
(2,754 Views)
Yep, that is a problem.  Go back to here and download the 8.2.1 version.
(2,734 Views)
thank you , this helped!
(2,702 Views)
