Tektronix TDS 3000 Series labview driver how to set "AUTO" TRIGGER
i download the labview driver for tds 3000 series, but i can not find the auto trigger vi, how to set auto trigger for the tds 3014C using the driver.
thank you!
(3,931 Views)
Hello Pan,
         It looks like you should try using the Configure Trigger Modifier VI:
19159iF0A0C90C087CC4DA
Cheers,
NathanT
(3,909 Views)
When you are having problems finding a function in a driver, what you can do is load the VI Tree function and then do a text search. In this case, you could have searched for 'Auto'. This would have returned 14 results. The above mentioned function is one of the results. The better you are familiar with the programming manual and the actual command, the better you can refine the search.
(3,904 Views)
