Tektronix oscil in continuous meas mode via GPIB-USB-HS
Now time I can handle Tektronix TDK784A oscil only in "single sequence" mode for getting one waveform with config that specified into VI.
1.It is possible to organise mea-nt process in continuous mode, when VI shows similar thing that displays on oscil?
2.Also, is any away exist to organise measure process with setting for oscil channels sets in oscil (in single sequence mode chanell settings sets throw VI)?
Thanks for help.
(3,790 Views)
Accepted by topic author Serg1987
Hi Serg,
What driver are you using to control your device? We have a driver available for your device on our driver network www.ni.com\idnet
Tektronix tktds7xx Oscilloscope
You may find the example vIs useful for learning how to control your device. If you are still having issues let us know what VIs you need help with and we would be happy to help you.
Scott M.
(3,768 Views)
Thanks, Scott, in now  almost clear
(3,714 Views)
