04-02-2008 01:10 PM
04-03-2008 11:23 AM
04-03-2008 12:02 PM
04-04-2008 08:44 AM
Hello Francisco,
Are you still deciding on which hardware to purchase? I thought you had a
PCI-GPIB and a USB-GPIB? I'm not sure I understand where the ENET
(Ethernet-GPIB) comes into play. Is there another reason why you would
want to use the ENET (your instrument is located far from your PC for
example).
As for your application, it seems reasonable to use a single PC to control the
scope and acquire data from it. Since you can only have one controller in
charge at any point in time, you will not be able to control the scope and
acquire at the exact same time. You will need to send it the commands for
the settings and then send it the commands for the acquisition
(sequentially). Whether you do that from one computer or from two
different computers (passing the control to a different GPIB board) will result
in similar performance. Is there another reason why you need to use two
computers for this?
Have a great weekend.
