Telnet Comm Run Time Error
I'm running VIs (LV8.6) under TestStand 4.1.
The following message is from a Telnet Read/Write vi.  I usually open the Telnet connection at the beginning of the test and close it at the end.  Sometimes there is a gap of long time without any telnet activity.  I set the timout of the Telnet connection to 1 hour.
Any idea what this error mean?
------------------------------- Run Time Error ----------------------------------------------------
A Run-time error has occurred in step: Remove All clocks Priorities
Sequence: Select_TMU_input
SequenceFile: D:\views\quad3_HLXC1536\NPI\TESTER\Work\HLXC1536\Seq\HLXC1536.seq
Error Message: TCP Read in NI_InternetTK_Core_VIs.lvlib:Telnet Buffered Read.vi->NI_InternetTK_Core_VIs.lvlib:Telnet Read.vi:1->TelnetReadWrite.vi->TelnetReadWrite.vi.ProxyCaller
Error Code: 62
Rafi
(3,826 Views)
Hi Rafi,
There is a discussion of Telnet timeouts in another forum post which I think applies to your issue. Take a look at that and see if it answers your question.
Stephen S.
Applications Engineering
(3,807 Views)
