Temperature Control MLC9000+250 west by Ethernet/IP
Someone could help me?
I am trying to do the protocol by Ethernet/IP for temperature control west model MLC9000 + BM250 S160 EI
I have a software MLC 9000+ workshop, but I can`t find more information or documents about it.
Best and Regards
Kelbert
Message 1 of 9
(5,556 Views)
I'm sending to you some tutorials about TCP/IP using VISA:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
https://www.ni.com/en/support/documentation/supplemental/21/command-based-communication-design-patte...
https://www.ni.com/en/support/documentation/supplemental/06/basic-tcp-ip-communication-in-labview.ht...
https://forums.ni.com/t5/Reference-Design-Content/Multi-Client-Server-Application-Design-Pattern-usi...
You can find some examples of TCP/IP clicking in Help>>Find Examples and searching for "tcp".
Best Regards
Luciano Borges
National Instruments Brazil
Message Edited by Lucianogob on 04-15-2009 10:08 AM
Luciano Borges
Test Development Engineer
Message 2 of 9
(5,543 Views)
Hi luciano,
I can't find any commands to send and get's answer for this instrument control, I don't have documentation about the protocol that I need for the Instrument control by Ethernet/IP.
I would like that somebody to have a documentation of the protocol of this or where I can research this.
Thank you
Kelbert
Message 3 of 9
(5,539 Views)
Hi Kelbert,
I'm sending to you a link that talk about Ethernet/IP in LabVIEW.
In this link you can find another link to download the Ethernet/IP Driver and VIs. When you install it, it comes with a great documentation about how to use the Ethernet/IP.
https://www.ni.com/en/shop/seamlessly-connect-to-third-party-devices-and-supervisory-system.html
Let me know if you have any question.
Regards.
Luciano Borges
Luciano Borges
Message 4 of 9
(5,524 Views)
Accepted by Kelbert
Hi there,
It`s good a link that you send me about Ethernet/IP in LabVIEW.
I have tried 2 ways:
One fo them that I tried with a llb modbus ethernet, but I guess the problem that I don`t know with which is the start adress I need to put it out I don`t have any documentation or imformation of controller that I have here.
The another one I tried with configure modbus I/O server, but there are some probleml.
Check it out the add attachments.
Best Regards
Kelbert
Message 5 of 9
(5,521 Views)
This problem usually occur when the address is not right. Don't you have any information about the address for your device?
Regards
Luciano Borges
Luciano Borges
Message 6 of 9
(5,487 Views)
Hi Luciano,
I don`t any information about it. I have tried to contact the supplier but I didn`t have a success.
About the problem that I posted I guess I can`t use the procotol with Modbus Ethernet because my deveice is Ethernet/IP and I can`t do with the llb Modbus, I think so.
Best Regards
Kelbert
Message 7 of 9
(5,478 Views)
Te envio dos enlaces.
Uno es una introdución al Modbus y el otro tiene una library de Modbus para el LabVIEW:
https://www.ni.com/en/shop/labview/introduction-to-modbus-using-labview.html
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Cordiales Saludos
Luciano Borges
Luciano Borges
Message 8 of 9
(5,473 Views)
I have tried to contact the Technical Support about the Temperature Control of west, but  they don`t have information about Ethernet/IP protocol.
I decided to change the Ethernet/IP to Modbus RTU, and I have already done without problem.
Thank`s for help!
Kelbert
Message 9 of 9
(5,262 Views)
