Termination Character in VISA configuration
Hai
I am trying to change the default termination character (0A) to 'End of line' constant(0D0A) in VISA configuration.
  • I had already gone through different discussion forums, and found that End of line cannot be replaced in place of termination character.
  • But I want to know ,is there any other way to change the Termination character to End of Line Constant (0D0A).
(1,301 Views)
The termination character can only be a single character.  In your case, just leave it as the Line Feed (0x0A).
(1,281 Views)
If the termination Character is enabled with Line feed (0×0A), the received data is splitting whenever the 0A occurs .
(1,276 Views)
What are you trying to communicate with?  Do you have a defined communication protocol?
(1,236 Views)
