Test & Measurement Setup
Hi everyone!
I want to renew an old test/measurement setup involving the instruments listed below:
Tektronix TDS3032B - Oscilloscope
Keysight Technologies E4416A - Power Meter
Keysight Technologies E4445A - Spectrum Analyzer
Keysight Technologies  66000A - DC Power Module
The instruments are used for testing and taking measurements on a certain device and the tests are controlled using an old TestStand version on an even older PC using windows xp. The instruments are operated using GPIB interface.
I want to upgrade to a newer PC- and TestStand version. Thus, I'm looking for suggestions to what setup to use in regards to PC and a new GPIB-controller card.
Any ideas are appreciated!
Spole
(2,773 Views)
Hello Spole!
What GPIB interface are you currently using? GPIB has not changed in the last decade(s), so there is a chance that you can re-use your old interface.
Most flexible is probably an GPIB to USB interface like NI's GPIB-USB-HS+. Regarding the PC itself there is no limitation, just pick any that suits your general needs.
Side-node on NI GPIB adapters: Buy it originally, not from ebay. There are lots of fake older models GPIB-USB-HS (without the + symbol) around on ebay for 15% of the original price. They do not work. You'll notice things like "Original National Instrumens" (missing "t") using original NI pictures, but then a description like "High Quality, but not original", "made in China", etc.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,746 Views)
