Test equipment as objects using classes & inheritances
Yeah, the 'interface' class introduced in LV2020 is a boon to HAL/MAL.
With MAL/HAL you get flexibility but lose performance (you might have to implement instrument-specific redundant operations just for the sake of simplifying).
If you or your company is looking for a professional consultation and implementation, please contact me.
Santhosh
Soliton Technologies
Message 11 of 13
(764 Views)
Thanks for the offer, though I'm a LabVIEW programmer myself just trying to learn. Seems like MAL is now easy and clean to implement with interfaces.
Please join the conversation to keep LabVIEW relevant for future engineers. Price hikes plus SaaS model has many current engineers seriously concerned...
Read the Conversation Here, LabVIEW-subscription-model-for-2022
Message 12 of 13
(756 Views)
@crossrulz wrote:
@WavePacket wrote:
So, if I'm understanding things correctly the HAL is 1., and the MAL is 2 through 4?
Technically, 2 though 4 is the HAL.  1 is just a low lever driver.  A MAL would be a "Read Spectrum" class that uses whatever instrument is required to take that measurement, whether it is an OSA, oscilloscope, etc.  But this is all semantics.
Personally, I have not found a good way to actually do a MAL.  So I would not worry too much about that.
Just thought that I would add that I'm getting convinced that MAL is achievable rather seamlessly using interfaces. As an example, you could have an interface with "Measure Voltage" as a method returning a double. Voltmeters, sourcemeters, o-scopes could all inherit from that interface and implement the method "Measure Voltage" as appropriate.
You could write your main test-software using just the interface. Seems like a MAL.
Message 13 of 13
(740 Views)
