Testo 350 toolbox 2012 (USB)
Hi, i am trying connect with a Testo 350 Maritime: http://www.testo350.com/350-maritime.html
It uses a new toolbox bases on USB dll.
It have several DLl´s, the most important are "testo3XXT.dll" "testo350SPI.dll" "testoEmUSB.dll", each has its functions, but all are necessary.
When you import a dll whith Labview shared library  manager tool (tools->import->shared library (.dll)), you need a header (.h) to define the functions.
All ok, but if a function of a library need a other function from other library, labview crashed.
For example, testo350SPI.dll need used testoEmUSB.dl, and it show error "the program can not start because lack testoEmUSB.dll" (i load it before).
(5,059 Views)
In testo 330, they have a compilation of dll´s and functions on a (testo330Base.dll).
Can i create somethig similar to this?
(5,048 Views)
These are the libraries and an example made in visual-studio2010
(5,046 Views)
More
(5,045 Views)
Test my app please.
Other solution is use the example application from testo ((t350_example.exe) include on the testo toolbox upload by me). using the activeX functions.
Can anyone help me please?
PD:This I have already published in: http://forums.ni.com/t5/LabVIEW/tchar-nicht-definiert-bei-DLL-Einbindung/td-p/1935967/highlight/fals...
but I have not received help.
(5,044 Views)
