The TRIGGER LIST function is not working.
I am trying to change the voltage output on several Agilent 661xxA modules simultaneously. The TriggerList functions is supposed to do this but it is not working. Only one of the power supply modules is turned on when I execute the fire the trigger.
(3,330 Views)
Greetings,
Are you using this device's Instrument Driver in the same program as the GPIB 488.2 function TriggerList? This could be causing the issue. Mixing these VIs can be problematic.
Spencer S.
(3,330 Views)
